st170 confused by sensor??
Old Aug 21, 2010 | 09:35 PM
nottsnic's Avatar
nottsnic
Default st170 confused by sensor??
hi all, have just joined up had my st for a couple of months now, ive noticed what looks like a screw in water temp sensor but its just clipped to the side of the battery near the coil. has 2 wires but not sure what its for.
Old Aug 21, 2010 | 09:55 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
I've seen this on a couple of st170's, no idea what it is though.
Old Aug 21, 2010 | 10:14 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
They've all got them - don't worry about it
I believe its part of the ECU monitoring engine bay temperatures to switch between low and high speed cooling fans.
Old Aug 21, 2010 | 10:20 PM
nottsnic's Avatar
nottsnic
ok thanks for the info.
Old Aug 22, 2010 | 08:38 PM
RichieST's Avatar
RichieST
Yes its an underbonnet temperature sensor. They seem to get quite hot under there because the engine bay is quite small, so they stick a sensor in for if it gets a bit toasty under there!
Old Aug 22, 2010 | 10:19 PM
mikey p's Avatar
mikey p
they were meant to be in proper fitted location but as they got a little warm ford did a bodge job and put them there so they would make the fan come on more. u will also notice that the fans come on sometimes when they really don't need to be because of there location.
Thats the story i heard anyways
Old Aug 29, 2010 | 12:58 PM
ST83's Avatar
ST83
Hi all, I purchased a focus ST170 about 6 months ago & having a few problems, I have a scratching sound when I switch off the engine ( around the oil pressure gauge area )
Engine sounds tappy/ticking
Vibrating accelerator pedal above 80 mph
Some loud knocking noise, not sure where it's coming from but sounds really rough on idle. The noise goes when I apply the clutch, have fitted a new clutch & slave valve cyli nder. Dual mass flywheel was slightly worn but ok. Have been told this sounds normall for the st170 & it's the 5th gear idle in the gearbox but I am not convinced.
I would be grateful for any help on these problems or advice
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
lime
Sep 25, 2015 06:56 PM
