Hole in gearbox casing....can it be repaired?
Old Aug 21, 2010 | 09:05 PM
kaisersolsay's Avatar
kaisersolsay
Default Hole in gearbox casing....can it be repaired?
See 2mm hole below.....can it be fixed?
[IMG][/IMG]
Old Aug 22, 2010 | 07:21 AM
Yes very easily, with a nice TIG weld, access looks good and not covered in oil so is easy enough to do.
Old Aug 22, 2010 | 05:12 PM
kaisersolsay
result!
Old Aug 22, 2010 | 05:21 PM
graham c's Avatar
graham c
try some chemical metal in it first matey
Old Aug 22, 2010 | 05:22 PM
kaisersolsay
Went to Halfords today but couldnt find any. Will try the bigger Halfords in Dundee tomorrow. Cheers!
Old Aug 22, 2010 | 05:24 PM
adam151082's Avatar
adam151082
or drill and tap a small hole and super glue a grub screw in there
Old Aug 22, 2010 | 05:36 PM
kaisersolsay
How do you split the transfer box from the gearbox? I removed all bolts and tried to pull apart but the middle shaft must also need to come out first before splitting?? When I had this box on the 4x4 there was a grinding noise when moving away in 1st. I think the sprockets inside have thrown a tooth.
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
mjonathan24
Oct 29, 2015 10:39 PM
rsguy
44
Sep 29, 2015 03:29 PM
