Minimum hight 4wd Cylinderhead
Old Aug 20, 2010 | 04:17 PM
Yogi.'s Avatar
Yogi.
Default Minimum hight 4wd Cylinderhead
hi, can somebody tell me what is the minimum height of a 4wd cylinderhead?
cheers
Yogi
Old Aug 21, 2010 | 08:47 AM
LHD220Turbo's Avatar
LHD220Turbo
ideally you do not want a head lower than 138.68mm, however i have seen many many people use heads with a lower measurement.
The valve seats become dangerously thin with the low thickness of the head
the diagram shows the valve area which becomes to thin, the more you skim off the head, the greater the risk
Old Aug 21, 2010 | 09:33 AM
evo-vlc's Avatar
evo-vlc
When I bought my sapphire, ran a lot, but at idle was unstable and sometimes stopped, the distribution was broken 6 months later and remove the cylinderhead was really lowered the rectifier said he was out of measures and that they had worked hard to level up the valves up and have more camera compresion. thanks that I had my sapphire catalyzed the complete engine to use the cylinderhead.
Old Aug 21, 2010 | 10:56 AM
Yogi.'s Avatar
Yogi.
thanks!!
Old Aug 22, 2010 | 07:16 AM
Depends how much power/heat you are getting.
The seats can be pinned if the head is very skimmed so it doesn't have to be thrown, but as said seen much lower ones used without problem.
I think the "ford" figure was down to the fact they would be warranty jobs.
Old Aug 22, 2010 | 07:36 AM
155lee's Avatar
155lee
i seen a head on ebay which had been skimmed so much the valves had been milled.when i was wondering about head thickness i did a search and there was a thread and stu at msd had posted up pics and sizes of what was good or bad.it was quite detailed.
Old Aug 22, 2010 | 08:12 AM
LHD220Turbo
yeah, its here https://passionford.com/forum/techni...thickness.html
you need to be a gold member to see it tho
dojj
28
Sep 11, 2015 10:00 PM
focus2351
Sep 9, 2015 09:33 PM
Ben26
Aug 27, 2015 08:56 PM
sridgett
15
Aug 3, 2015 07:26 PM
lockie
Jul 31, 2015 10:03 PM
