Standard Pistons?
Old Mar 22, 2004 | 10:15 PM
Default Standard Pistons?
was just wondering if 330bhp is the absolute maximum power you can run with standard pistons? if the standard pistons in my engine were in next to new condition, what is the absolute MAX power i could run on them as i was wondering what they are really capable of
cheers
DaveRS
Old Mar 22, 2004 | 10:32 PM
Dave,
Age old question and you'll get a wide array of responses.
Personally I'd only run as you say, a max of 330bhp through them.
Although, if new pistons in good health then, people like Stu can use clever mapping and there's nothing to stop you running 400bhp (with the RIGHT set up)
Personally, I'd lower your comp ratio on anything above 330bhp but again only for safety reasons and my personal opinion.
There's a post on the main board a few days back about this, might be worth taking a look
Old Mar 23, 2004 | 07:20 AM
is it possible to have the standard pistons skimmed to lower the compression or do you have to buy a new set?
Old Mar 23, 2004 | 11:07 AM
The standard cossie pistons are Mahle ones which are forged.
If in GOO nick then you could get them skimmed to your required comp ratio, but best to be safe and get new set IMO.
Old Mar 23, 2004 | 12:54 PM
Switch's Avatar
Switch
loads of peeps run more than 330 bhp with std pistons, IF the engine is in good nick you will be fine for alot more
Old Mar 23, 2004 | 10:14 PM
cool cheers lads
little bram
Oct 4, 2015 12:13 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
L1AM_RS
Sep 23, 2015 03:27 PM
ajamesc
Sep 8, 2015 06:51 PM
