xr4x4 diff with 4x4 gearbox?
Old Aug 15, 2010 | 10:12 AM
cozziepj's Avatar
cozziepj
Default xr4x4 diff with 4x4 gearbox?
can anyone tell me if you can use xr4x4 diffs with a 4x4 cosworth gearbox? and if you can any pros and cons?
cheers
Old Aug 15, 2010 | 07:59 PM
2ndGear's Avatar
2ndGear
if it is a 2.8 or 2.9 4x4 the ratio is 3.62 and the rear diff is a LSD. If the diffs are from a 2.0 4x4 they a 3.9 ratios and the rear is not a LSD
But to answer your question - yes you can
Old Aug 15, 2010 | 10:36 PM
cozziepj's Avatar
cozziepj
cheers its a 2.9 h reg car, will the speed be much difference from the cosworth ratioos thanks
Old Aug 18, 2010 | 10:48 AM
2ndGear's Avatar
2ndGear
the diffs are the same a cozzy
Old Aug 18, 2010 | 04:29 PM
cozziepj's Avatar
cozziepj
thanks mate
Old Aug 22, 2010 | 06:42 AM
kaisersolsay's Avatar
kaisersolsay
So what is the effect of fitting a 3.92 instead of a 3.62 in terms of top end speed?
Old Aug 23, 2010 | 01:07 PM
kaisersolsay
bump
Old Aug 23, 2010 | 01:11 PM
chaffe's Avatar
chaffe
Turbocharging Technician
the gearbox and diff will have the same ratios mate or else you will overheat the viscous coupling in the transfer box. therefore you cant change the rear diff ratio without changing the front diff ratio or transfer box ratio.
Old Aug 23, 2010 | 03:21 PM
mick's Avatar
mick
2.0 4x4 rear diff is lsd....
as long as front and rear diffs are the same ratio all should be fine..
the 3.92 is a gearchange nightmare , great acceleration but not so good top end , mpg will suffer both on town and motorway..
Old Aug 23, 2010 | 07:50 PM
kaisersolsay
How do I tell if I have a 3.92 or 3.62? Is the diff stamped?
Old Aug 23, 2010 | 10:00 PM
mick's Avatar
mick
there should be a small id plate or failing that there is a way of turning the prop end and counting the output but i'm not sure on the details..
Old Aug 26, 2010 | 12:44 PM
2ndGear's Avatar
2ndGear
the 2.0 4x4 isnt a LSD, people think it is as it has the bolt on shafts. I have had 4 of these and not one of them has been a lsd.
Fords were saving money at the time and didn't fit a lsd in the 2.0 4x4!!!!!!
Old Aug 26, 2010 | 12:47 PM
chaffe's Avatar
chaffe
i had a 2.0 litre with an lsd but who is to say it was original? 20 year old car with unknown history and a million owners...
Old Aug 26, 2010 | 01:13 PM
mick's Avatar
mick
the 2.0 is virtually the same as the 2.9 with different ratios, , if no lsd how is 4x4 achieved??
the service literature and the 4x4 dohc both state it has a viscous coupling in the rear diff...
i have had more than my fair share of 2.0 4x4's , in some the coupling was u/s so gave the appearance of not being lsd.....
Old Aug 26, 2010 | 09:34 PM
jamie's's Avatar
jamie's
lots of 4x4 cars dont have a rear lsd so i dont understand what you mean by that?
i fitted 3.9 diffs to an escort not long ago and it wasn't lsd,
but it may just have been pumped, i assumed it wasn't lsd
Old Aug 26, 2010 | 09:39 PM
iansoutham's Avatar
iansoutham
OCD Victim
All Sierra and Granada 4x4 rear diffs have LSD, regardless of engine (except Scorpio from 1994 onwards as that had an open diff but electronic traction control).
I have a 2.0 DOHC 4x4 with an LSD as standard using a 3.92 ratio (even says it in the Ford literature, repair manual, parts catalogue, spec list as detailed on the production line).
I also have a 2.9 4x4 rear axle with LSD using a 3.62 ratio sitting in the garage for my other halfs 2000e.
Also, I'd would recommend listening to Mick. Between him and Dojj, they have probably taken apart more Sierra and Granada cars and diffs than most Cossie owners have broken.
Old Aug 27, 2010 | 07:44 PM
2ndGear's Avatar
2ndGear
for christ sake only 2.8 and 2.9 4x4 have a rear lsd (sierra or granada)
forget what the literature says. The literature even says a 2.0 efi pinto uses a steel crank shaft - it doesnt.
If in doubt speak to barra, gears or cts.
Old Dec 4, 2011 | 01:48 PM
martysport's Avatar
martysport
Never heard such rubbish LOL
yatta
May 21, 2016 10:31 PM
mark r
Sep 29, 2015 07:27 PM
rog
Sep 16, 2015 03:00 PM
Fezman1
Sep 7, 2015 09:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
