Mondeo PATS
Old Aug 14, 2010 | 12:25 PM
iluvaford's Avatar
iluvaford
Default Mondeo PATS
My Mondeo is a 7/99 T 1.8 Blacktop manual.
When changing the ECU, i should change the module around the ignition and key fob.
Is there any other modules/boxes under the dash that should be changed or is it just that simple?
Old Aug 14, 2010 | 06:40 PM
No need to change the pick up around the ignition barrel, just the key and pats/ecu.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
