Swivel wall tv mounts, which one?
Need to get a swivel mount for the telly so what's out there?
It's only a small 19" one so not that big but I'm not sure I want it to be side to side swivel as well as top and bottom.
And if I get a bigger tv later on I don't what to be drilling more holes in the wall, it's going to go on an internal brick wall so no problems with hanging it and it might even go on an external brick wall so deffo not a problem there.
http://www.alphasondesigns.com/produ...atID=56&varID= - really nice brackets this range.
If you went bigger than 26" then yes you might need a bigger bracket, but it does have up to 400x200 mounts, so some 32's may fit.
For simplicity of fixing, use these: http://www.directbuildingproducts.co...s3.php?id=1525 - I've NEVER had a problem with these fixings - very easy to go in and very very secure. If you call DBP they'll post a few out to you, saving the Ł9 delivery charge!
HTH
Chris
HTH
Chris
mk3ste
Oct 17, 2021 10:09 AM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
