General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
hey guys, my turbo is only boostin quarter bar now instead of half.. any ides why?? jst had dump valve recently fitted could that hav anythin to do with it?? thanks
Sounds like it is in limp mode - some ST's have suffered this with certain dump valves. Get a dreamscience induction system then you get the full wastegate flutter and the dump valve noise.
Not had new tyres fitted recently have you? I know that if there is a big difference in wear between front and rear tyres then it may bring the warning light on. There was an update for the ECU available from ford to fix this!
