Cosworth BOA Hose pipe, where from ?
Old Aug 11, 2010 | 08:42 AM
NoGutsNoGlory's Avatar
NoGutsNoGlory
Default Cosworth BOA Hose pipe, where from ?
I need to buy the top radiator hose pipe with the bleed screw as mine has blown. Any idea where can I get one ? Aftermarket or orginal it doesn't ,ater as long as it fits. Please help
Old Aug 11, 2010 | 09:01 AM
The Youth.'s Avatar
The Youth.
Ford or even an normal 2.9 Granada or xr4x4 one might fit.
Think sfs or samco do these mow and also rose
Steve
Old Aug 11, 2010 | 09:07 AM
capri280's Avatar
capri280
I have one here postage not a problem
Ring Eugene on 07815879956
Old Aug 16, 2010 | 08:50 AM
NoGutsNoGlory
any one else can help ? pleasee
Old Aug 16, 2010 | 09:37 AM
dojj's Avatar
dojj
Resident Wrestling Legend
samco do them
the normal granada's have them
but not too sure if they have the bleed screw in them or not
you can always try top boss performance as well
Old Aug 16, 2010 | 09:48 AM
NoGutsNoGlory
Originally Posted by dojj
samco do them
Found samco on ebay, but it comes without bleed screw.
How much of a problem would it be to not have the bleed screw ?
Old Aug 16, 2010 | 09:57 AM
dojj's Avatar
dojj
it's the highest point of the air system so that's where the air collects, best to get one with the screw if you can, or put a bleed screw into it by cutting the pipe and slotting some sort of metalic thing in there with a bleed screw built in
i know they are available but couldn't tell you where to get one from sorry
Old Aug 16, 2010 | 10:12 AM
m4tt274's Avatar
m4tt274
just get one from a breakers yard mate, they are full of granada cosworths.
here the number to the sierra/granada breakers i use locally to me. called sierra shack and the guys sound. 07804833334 he will have one, but make sure he sends you the right pipe lol
Old Aug 18, 2010 | 08:21 AM
NoGutsNoGlory
Phoned, no luck they don't have them. Thanks anyway
Old Aug 18, 2010 | 08:50 AM
RS500/364's Avatar
RS500/364
If you are stuck Paul at roose see signature can copy one like yours !
Old Aug 18, 2010 | 09:03 AM
NoGutsNoGlory
Thanks, mail sent
YODI
Aug 30, 2015 01:12 PM
Dicko&Vacant
Aug 21, 2015 05:59 PM
muffster
Aug 17, 2015 08:17 PM
Aug 14, 2015 07:29 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
