2WD Cosworth mods to get the power down ?
Old Aug 10, 2010 | 09:45 PM
Mark V8's Avatar
Mark V8
Default 2WD Cosworth mods to get the power down ?
What is the most cost effective rear axle mod to get decent 1/4 mile times ?
Thanks
Mark
Old Aug 10, 2010 | 10:46 PM
jamie's's Avatar
jamie's
i fitted solid rear beam mounts to mine,
made a noticable differance
Old Aug 10, 2010 | 11:13 PM
botters's Avatar
botters
competant bodger
6 degree rear beam properly set up, rods your man to ask his is circa 800bhp iirc and puts power down perfectly
Old Aug 10, 2010 | 11:22 PM
m4tt274's Avatar
m4tt274
a fat pair of r888's and solid mounts would be the most 'cost effective' id of thought. maybe some camber shims?
problem with the cossy's is they squat and the wheels go into negative camber.
Old Aug 11, 2010 | 06:08 AM
Mark V8's Avatar
Mark V8
Thanks for the info
What is best, shims or 6 deg beam mods ?
I was under the impression that the 6 deg mod was to help with the cornering, does it also help with the negative camber issue when the rear squats ?
cheers
mark
Old Aug 11, 2010 | 06:29 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Originally Posted by Mark V8
Thanks for the info
cheers
mark
A new 6 degree beam is the best option. It helps handling and traction full stop. Stops the camber change when launching and stops the wallowy barge like feeling round the bends
Old Aug 11, 2010 | 07:48 AM
Markb_s1's Avatar
Markb_s1
I would have said the best option for a decent 1/4 is a live axle
Old Aug 11, 2010 | 08:05 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Proper Rear Beam, Jaguar 'Power Loc ' diff, Chassis connector bars, Leda coilover, Rear Twin springs to limit dip & Toyo 888 of Dunlop DO range of tyres. That lot will allow 800bhp down in 2nd gear without a hint of the typical Cossie problems.
If you want your car simply for 1/4 miles & its not a road car best speak to someone like Danny B at Adrenaline.
Old Aug 11, 2010 | 08:16 AM
I would live axle it if 1/4 only car, or just have the location points on the beam moved and new adjusty arms made with solid bushes.
Old Aug 11, 2010 | 08:21 AM
JamesH's Avatar
JamesH
6° beam, decent diff and tyres will most likely handle the power you have
Old Aug 11, 2010 | 08:06 PM
Mark V8's Avatar
Mark V8
Thanks for all the hints
It's not going to be dedicated a 1/4 mile car, just a bit of cheap-ish fun with a stock 7 1/2" diff, T56 gearbox, 215/40/17 Yokahama parada's and souped up ford 302.
My last V8 powered Sierra used to squat hard on the line and run the tyres on the edges
Mark
Old Aug 13, 2010 | 10:00 AM
JamesH's Avatar
JamesH
Mark
It is the beam that causes this, which a 6° item will fix!
Old Aug 13, 2010 | 12:31 PM
Garage19's Avatar
Garage19
Thanks
Mark
Don't know why people keep saying 6 degree beam. I think they have been brain washed by people that sell 6 degree beams like its some sort of magic number.
For pure 1/4 mile times you would want a 0 degree beam so fully trailing arms not semi. This way the camber will not change.
To improve it further you could install a de dion tube to effectivley to link both independant arms and convert to solid axle.
Old Aug 13, 2010 | 12:37 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Because it's easiest and most cost-effective option for a road car...
Probably best for a car that'll never see an MOT station (ie, one that never sees the road).
Old Aug 13, 2010 | 12:53 PM
Garage19's Avatar
Garage19
I wouldn't call a £1500 rear beam cost effective. Especially if its not ideal for what you want to do with it. Mark is a very competent engineer and i suspect what ever option he chooses he will be making himself so that gives him free reign over the design.
The MOT station doesn't care what design your rear suspension is as long as it in good condition ie no play in bearings and doesn't bind. There are plenty of cars with de dion set ups that pass mots every year.
Old Aug 13, 2010 | 01:01 PM
cozmeister's Avatar
cozmeister
More boost Igor!
No need to get excited. Lighten up! You completely missed my point...
I know that it doesn't matter what you have for an MOT I was pointing out that going for all the expense of replacing the whole rear end design on a car that spends less than a minute of every year doing quarter mile runs is a bit excessive.
Old Aug 13, 2010 | 04:13 PM
JamesH's Avatar
JamesH
Where did you get £1500 from?
Most 6° rear beams are £1000. Have you driven a car properly setup with one?
Oct 9, 2015 07:38 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Old ford
Jul 31, 2015 06:50 AM
