How do I no which Altenator I need?
Old Aug 10, 2010 | 02:05 PM
Fordmad!'s Avatar
Fordmad!
Default How do I no which Altenator I need?
I need a new Altenator for my Xr3i. There is a choice of two a 55 or 70 watt.
How do I find out which is the right one?
Old Aug 10, 2010 | 03:53 PM
Fordmad!'s Avatar
Fordmad!
Anyone?
Old Aug 10, 2010 | 05:03 PM
Either one will do the job, if you want to replace what's there already just have a look, should say what one it is, but even a 55amp will do, might want to go for the 70 though if you have a bit of audio in here amps etc.
Old Aug 10, 2010 | 05:14 PM
iansoutham's Avatar
iansoutham
OCD Victim
Look on the alternator itself for the red wire. If it goes into a plastic block made up of 2 red wires and a blue wire all together then it is a 55A, if it has separate red and blue wires that have their own nuts to connect it, then it is 70A.
Also, if you have a heated windscreen, you will have a 70A as standard (unless replaced by someone else who was too tight to buy the right one).
Old Aug 11, 2010 | 08:18 AM
Fordmad!'s Avatar
Fordmad!
Cheers. Yes its heated front and back so imagine it will be the 70A. Thanks!
Fordmad!
Sep 4, 2011 12:51 PM
paddy145
Mar 10, 2011 01:30 PM
Ellie
17
Jul 6, 2009 09:12 PM
AJ-RST1
Jul 2, 2009 06:04 AM
DaveEscos
Apr 3, 2006 12:04 PM
