3dr and 2wd sapp fuel tanks-same or not?
Old Aug 9, 2010 | 09:52 PM
1374lee's Avatar
1374lee
Default 3dr and 2wd sapp fuel tanks-same or not?
Just trying to find out if the fuel tank is the same on a sapp 2wd as a 3dr cossie.Ford don't make them for the 3dr anymore,not sure about the 2wd sapp though.Can anyone help please.I'm talking about GENIUNE Ford tank not aftermarket.
I hope someone can possibly help.
MANY THANKS.Lee.
Old Aug 9, 2010 | 10:09 PM
james kiely's Avatar
james kiely
i always thought they were the same lee,but couldnt be 100%
Old Aug 10, 2010 | 10:51 AM
They were never 100% identical, but will fit each other, there were 5 different makers of tanks supplied to ford, the later pattern "MADE IN CANADA" ones are ok, the best ones imo were original kit early sapph, the swirl pots were made by a mercedes subsidiary and worked ace.
In short a 2wd and 3 door tank will replace each other no problem, externally they might have different bulges/ribs etc but will fit no probs, though you may find on some pattern the main breather that goes from the tank to the filler neck needs a extra inch or so rubber extension, this is about 1/2 diametre, opa or fuel pipe etc can be used, note this is the breather not the main filler which will fit no problem as it sits a long way into the tank.
Make sure it has a swirl pot, can see through the float hole, or see if it has spot weld marks around the 10" diametre round metal shape underneath.
bigluke200
14
Sep 2, 2015 10:35 PM
mint_s2
Sep 2, 2015 08:58 AM
Indyrs
20
Sep 1, 2015 09:04 AM
FlashRS
13
Aug 31, 2015 06:02 PM
Old ford
Jul 31, 2015 06:50 AM
