need help with focus tdci please
Old Aug 9, 2010 | 12:09 PM
morto's Avatar
morto
Default need help with focus tdci please
hello all, i have a focus 53 plate tdci, there seems to be a issue with overheating, its pushing water back into the expansion tank i then have to turnn the car off as the needle will go into the red, after undoing the yellow cap for the expansion tank and waiting some time the water normally goes back down it will then drive ok at around 60 mph and some times the heater works and other times its cold, ive put a new thermostate in and a new water pump, so next step must be head gasket? ive just tryed some K seal but this has done nothing, theres no oil in the water and no water in the oil, what do ya think guys deff head gasket?
thnaks
andy
Old Aug 9, 2010 | 12:29 PM
RichieST's Avatar
RichieST
If you get it up to temperature and let it idle with the expansion tank cap off are you getting bubbles coming up through?
Does sould like head gasket, probably worth getting it to a mechanic for a sniff test etc!
Old Aug 9, 2010 | 12:34 PM
morto's Avatar
morto
etc!
yes mate bubbles, gona get a sniff test done
Old Aug 9, 2010 | 12:39 PM
RichieST's Avatar
RichieST
I'd say almost certainly head gasket then!
Old Aug 9, 2010 | 12:43 PM
morto's Avatar
morto
thanks mate, i thought the K seal might work just enuff to sell it but its done nothing
andy
Old Aug 9, 2010 | 01:00 PM
morto's Avatar
morto
rich do you now if the cylinder head bolts are stretch bolts? are can you use them again
andy
Old Aug 9, 2010 | 01:13 PM
RichieST's Avatar
RichieST
I have no idea I'm afraid mate!
tankybaby66
Feb 6, 2016 02:24 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
