Group buy on Hart Plenums...who's interested? *NOW WITH LINK TO GROUP BUY*
Old Aug 9, 2010 | 12:00 PM
JamesH's Avatar
JamesH
Default Group buy on Hart Plenums...who's interested? *NOW WITH LINK TO GROUP BUY*
So I've been chatting to a Trader on here, and we've come up with a good deal on the Hart Plenums
Who would be interested, we need 10 people
This plenum cover has been used to great effect on Rod Tarry's huge power Saff, and on Ade's too.
Mine would be going on my new engine, expected to make 480hp 480ft/lb and wouldn't be classed as overkill
Link to the group buy now added: https://passionford.com/forum/trader...t-plenums.html
Old Aug 9, 2010 | 12:02 PM
MONSTER's Avatar
MONSTER
What sort of money are you looking at?
Old Aug 9, 2010 | 12:03 PM
BRAMMER's Avatar
BRAMMER
What is the price?
Old Aug 9, 2010 | 12:04 PM
JamesH's Avatar
JamesH
Ł450 with throttle brackets
Old Aug 9, 2010 | 12:05 PM
R4N SS's Avatar
R4N SS
what is the last date you need to know by?
Old Aug 9, 2010 | 12:08 PM
JamesH's Avatar
JamesH
There will be a thread going up in the traders section this evening.
But basically, we'll be needing: Ł50 deposits, once everyones paid the deposit we can put the order in for 10.
Turn around from the order going in, and the parts beign ready will also be good
Old Aug 9, 2010 | 12:19 PM
james kiely's Avatar
james kiely
how big an improvement are they over the small turbo inlet james?
Old Aug 9, 2010 | 12:23 PM
BRAMMER's Avatar
BRAMMER
Who is the trader that they are coming through??
Old Aug 9, 2010 | 12:42 PM
BigErn's Avatar
BigErn
What power are they good for?
Old Aug 9, 2010 | 12:44 PM
JamesH's Avatar
JamesH
James, i remember Rod had a spaced 500 inlet, they put a hart one on and it jumped a considerable power and torque.
They'll be coming through Danny @ EP
Old Aug 9, 2010 | 12:45 PM
R4N SS's Avatar
R4N SS
pmsl at all the questions - bet you never expected that?
JamesH's Avatar
JamesH
BigErn, well what's Rod on now? 800 plus hp?
Old Aug 9, 2010 | 12:47 PM
JamesH's Avatar
JamesH
Doesn't bother me Ran i'll send Rod a PM and see if he can put some facts and figures up
Old Aug 9, 2010 | 12:48 PM
BigErn's Avatar
BigErn
Cool, I didnt know thats what Rod was running.
Old Aug 9, 2010 | 12:53 PM
dave cos4x4's Avatar
dave cos4x4
the power Rod has then you can probably see why it made a difference but will the difference be noticeble on lower spec,powered engines etc....maybe not.
Old Aug 9, 2010 | 01:02 PM
R4N SS's Avatar
R4N SS
pretty sure this was tried on a few different engines and it produced positive results all round
Old Aug 9, 2010 | 01:03 PM
JamesH's Avatar
JamesH
Well as said, Mark said it would be worth it on a 480hp Dave!
Old Aug 9, 2010 | 01:05 PM
dave cos4x4
ah..good to know then.
Old Aug 9, 2010 | 02:47 PM
BRAMMER's Avatar
BRAMMER
I'll find out if it would be beneficial for my spec
Old Aug 9, 2010 | 03:32 PM
stu21t's Avatar
stu21t
Basically it will improve any engine 450+
don't forget it's not all about peak figures.
These plenums will improve the running of any engine and also have better distribution across all 4cylinders.
Old Aug 9, 2010 | 04:08 PM
opposite lock's Avatar
opposite lock
i know the guy that used too/ gets these made up i had the booklet that showed some comparisons and improvements on 3 different dyno,s with different spec engines aswell.
not sure if i still have it but the one thing i recall was a big gain in terms of the egt being alot more even on each cylinder .
You could see from the figures how 1 and 4 cylinder suffers with the standard inlet.
I,ve just found the paperwork here,s a quick example they have printed if anyone is interested. 1 engine/guide obviously with results
500 hp engine (no spec) 500 inlet and TB difference
rpm psi cyl temps 1 2 3 4 av.mean temp c 1 2 3 4
4.5k 32 648 665 687 628 657 -9 +8 +30 -29
5k 30 614 630 641 590 619 -4 +11 +22 -29
5.5k 30 634 666 676 619 649 -15 +17 +27 -30
6k 30 620 634 651 604 627 -7 +7 +24 -23
sod writing the hart results down lolpmsl , but the 4 mean ex temp figures for the hart are, 596,651,681,683 respective of rpm. The cyl mean difference is as follows
1 2 3 4
+16 -18 +2 0
+11 -13 +7 -4
+3 -8 +9 -3
+2 -8 +2 +5 You can see cyl 1 and 4 are down the majority of the time , this plenum evens things out very well (easy to see in booklet)
As you can tell i have some spare time + being quite bored haha sorry 4 that but hope it helps a little even though its a bit sketchy on the diagram i made
Mike balls its come out horrid. scan through it, u maybe able to make it out. sorry guys my fault, was only trying to help .
Basically, buy one if your after realible big power with even inlet intake system
Old Aug 9, 2010 | 04:25 PM
Mike Kerbey's Avatar
Mike Kerbey
Im tempted by this, but promised my self I would stop spending money on mine
Old Aug 9, 2010 | 04:49 PM
JamesH's Avatar
JamesH
Opposite lock - any chance you could scan the booklet in?
Come on Mike, I know Ade got rid of his swedish style plenum for one of these
Old Aug 9, 2010 | 04:52 PM
capri-rs's Avatar
capri-rs
im up for one
Old Aug 9, 2010 | 06:17 PM
Danny @ Enhanced Performance's Avatar
Just added info and stuff in the traders parts for sale...
cheers danny
Old Aug 9, 2010 | 06:21 PM
JonnyBravo's Avatar
JonnyBravo
I heard that the castings are poor and very heavy requiring some finishing to be done to make them work well.
This was only what I heard somewhere but I don't know if the rough bits are sorted before Danny supplies them ? obviously the weight cannot be sorted.
Just worth knowing the facts before people buy them assuming they are perfect to use out of the box.
Old Aug 9, 2010 | 06:25 PM
They are a bit heavier but cant see why that would cause an issue and as for being rough inside well iv only seen a couple with some sharp edges and other than getting rid of them witch took me all of 5 mins iv always left them as is and they work awesome with no trouble..
cheers danny
Old Aug 9, 2010 | 06:28 PM
JonnyBravo's Avatar
JonnyBravo
Sorry Danny I was knocking the product, just had heard the rough casting, I appreciate its cast so unless its finished off its not going to be perfect.
Can't knock the price, even a proper Swedish is similar money and I'm told these are far better.
Old Aug 9, 2010 | 06:31 PM
pig's Avatar
pig
i run one of these on mine and made a decent differance on joe's engine dyno over both a standard 4x4 item and my old swedish type inlet,they are a bit heavier but i braced it with a rod with 2 rose joints to the engine mount via a mount lug on the bottom of the hart inlet.decent bits of kit these fellas imo
TWoods's Avatar
TWoods
Anyone got a pic of these? if its the ones im thinking of put me down for 1, possibly another 4.
Old Aug 9, 2010 | 06:35 PM
pig's Avatar
pig
not a great picture but mine
Old Aug 9, 2010 | 06:39 PM
JamesH's Avatar
JamesH
Great pic here guys
Cheers Focus 4x4
Old Aug 9, 2010 | 06:42 PM
M K's Avatar
M K
got mine direct from joe at bluesprint a while back as i heard nothing but good things about these so its going to be used on my new engine when its built,
rough pics but here is mine when it was being dummy fitted while building the car
Old Aug 9, 2010 | 06:57 PM
focus 4x4's Avatar
focus 4x4
Great pic here guys
Cheers Focus 4x4
Youre welcome James. BTW my plenum casting was spot on no problems at all.
Old Aug 9, 2010 | 07:00 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Hi
Have been asked to comment on the Hart Plenum.
It made 47bhp more Power on the Dyno than my 500 Plenum. Both used a 14mm Spacer & no other mods were done. I use it with a WRC 8 injector manifold & the pair cost Ł850 & has seen over 800bhp .
The casting was rough inside & Mark sent it to his head guy to be sorted.
Cant comment on gains at Lower Power levels but it certainly worked on mine. At Ł450 it seems a no brainer dont think anything else comes close for that money.
Old Aug 9, 2010 | 07:07 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
More bolt on goodies. New intercooler from Spec R just been proven, and now a group buy on hart plenum. Where does it end
Old Aug 9, 2010 | 07:10 PM
marco polo's Avatar
marco polo
to be honest it looks well made not only that i saw one of these on Dave's (DP)car about 2yrs ago and asked him what it was like, he said it was very good
for my spec engine dont think it's really needed as i use the small turbo escort with 14mm spacer good enough
i suppose on a engine over 500bhp it's well worth it
marco
Old Aug 9, 2010 | 07:11 PM
No probs mate its true rods was a bit rough inside as i know they wouldnt make it up but iv never had any probs and as you can see from mk s pics its nicely finished..
Also no need for a spacer at all unless you want more than 700 hp+
Any one wanting one will have to reply via pm or phone call or on the traders for sale section..
cheers danny
Old Aug 9, 2010 | 07:13 PM
marco
It will still give you better gains especially in the midrange torque ..
cheers danny
Old Aug 9, 2010 | 07:15 PM
CossieRich's Avatar
CossieRich
Danny,
I thought using these plenum's lost you midrange torque but gained you top end hp?
