help with hose for water cooled turbo
i am stuck on a problem. i have a mk 3 ecort with a 2.1 zvh in it, it has a water cooled turbo a wandering where to pipe it up for the turbo, i have piped it in but the car is running well hot. cheers
it normally runs as follows : top rad hose into top of turbo, bottom turbo hose into small (lefthand side) radiator hose. Most have found their car running warmer when the turbo cooling has been connected.
does it need to be conected, can i just buy pass it. also it runs like a bag of crap on start up and cuts out unless i keep my foot on the throttle. the temp is about a 4 mill away from red line. are the water temp sensors different from s1 to s2
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Aug 19, 2015 06:25 PM
