Cat d
Old Aug 6, 2010 | 09:37 PM
turbo1973's Avatar
turbo1973
Default Cat d
Can you get the cat d removed if so what do you need to do
Old Aug 6, 2010 | 09:42 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
i dont think you can matey
Old Aug 6, 2010 | 09:48 PM
saph_Al's Avatar
saph_Al
No it can't be removed but you can still register it without problems, cat C will need a VIC check and B ,A need to be crushed , although you can remove parts from a B Cheers Al
Old Aug 6, 2010 | 09:59 PM
vaughant's Avatar
vaughant
Now there used to be a way,you could take it to some sort of thatcham approved centre where if the repair was to a certain standard then they could remove the marker but I'm not sure if that's still the case.tbh mate I don't know why anyone would want to bother as cat d could be something as stupid as the car being keyed all over and needing a full repaint.Also,if it's had heavyish damage it won't be too hard to tell and you'll only be trying to hide it from a seller who probably won't care anyway.
Nov 1, 2015 06:53 PM
richierich1986
Sep 18, 2015 03:29 PM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
Fordmad!
Sep 4, 2015 01:42 PM
