stoneguard - how to?
Hi all,
I have a few questions surrounding this. What is the normal process of properly applying this - i.e.
Remove existing paint, prime/paint and then stone guard?
Also which company would you guys recommend?
remove all old stuff back to metal were needed with wire wheel ,etch prime ,seem sealer were needed (tigerseal) then stone chip lota different makes out there then paint over top that if you want colour on underside ,go a body shop surpliers they sort you out with all the above
chasemk2
Oct 30, 2012 09:38 PM
