will the engine fit
Old Aug 4, 2010 | 01:37 PM
shlongie's Avatar
shlongie
Default will the engine fit
Hi, will a engine out a 4x4 saphire cosworth fit my 2wd saphire cosworth if i change the flywheel and clutch for mine?? will all the wiring be the same??
cheers steve
Old Aug 4, 2010 | 02:03 PM
oldford's Avatar
oldford
Wiring is not the same. TPS sensor is different and wiring is switched and a 4x4 also has an Oxygen sensor (green top) and a knock sensor.
You should be able to run the engine with your sensors (including TPS) and ecu and without Oxygen sensor and Knock sensor.
Depending on the manifolds and turbo you use, you may need a remap.
Old Aug 4, 2010 | 02:15 PM
shlongie's Avatar
shlongie
id be using all my sensors and wiring, could i use the 4x4 t3 turbo on my 2wd manifold??? or can i run the 4x4 turbo and manifold???
Old Aug 4, 2010 | 03:07 PM
oldford's Avatar
oldford
You could use the 4x4 exhaust manifold and turbo - if it fits the exhaust.
Advantage is no more turbo damper. Disadvantage is the form of the manifold. The 2wd drive one is better - maximum torque at a lower rev range, probably more power also.
It all depends on how far you go. Standard, stage 1?
You also might need a remap to do this.
Old Aug 4, 2010 | 06:42 PM
AndyPen's Avatar
AndyPen
Dont forget the sump and oil feed etc
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
