transplant help please
Old Aug 3, 2010 | 10:17 PM
patton16i's Avatar
patton16i
Back in business
Default transplant help please
Its coming to the point when i need to choose the engine transplant for my rs 16i.Could anybody help with a few pointers?does the 2.0 black top hang on the same mounts as my escort?can a rs turbo gearbox be bolted streight on?is the mk5 rs 2000 engine the same as the 2.0 zetec but with cams?sorry for the boring questions but im struggling to be honest and would appreciate the help
Old Aug 3, 2010 | 10:40 PM
XR2's Avatar
XR2
Not sure about the black top. For the early Zetec-E you'll have to modify your CVH engine mount. And iirc you'll need a gearbox with the starter mounted behind the engine. So RS-Turbo boxes are a no-go. But the bolt pattern gearbox <-> engine will be the same.
Zetec-E is a development based on the CVH, so this is why this ZVH thing is possible.
RS2k 16V is a development based on the Pinto, so totally different from the CVH and Zetec. Chain-driven camshafts. 2.0 16V, 150 bhp. Good standard engine, more hp than the 2.0 Zetec. But less tuning parts available.
But why do you want to spoil your RSi with a 16V engine? CVH MFI with red twin coils is the only way to go in an RSi!
Old Aug 4, 2010 | 06:20 AM
jonny s2's Avatar
jonny s2
1.8 zetec would be more easier fit,you would still need to mod the mount and just as tuneable, fit some 130 spec 2.0 cams, an efi cvh flywheel,and use the standard b5 box, the rs2k engine is totally different, chain driven etc...
Old Aug 4, 2010 | 08:50 AM
benny1985's Avatar
benny1985
i would use a 2.0 zetec silvertop engine
use your flywheel and clutch , gearbox
you will have to have the engine mount modded so you can fit all 3 engine mount bolts in
if you like i can get a photo of where and how the mount needs to be moded ?
as im doing a zetec turbo in my fiesta
Ian1964
12
Jan 26, 2021 11:57 AM
paulhussein
May 25, 2006 05:38 PM
JimmyBoy
May 5, 2006 05:12 PM
zvhrst
39
Jan 4, 2006 09:29 PM
The Sludge
Nov 30, 2005 09:16 PM
