Ford Puma Discuss the Ford Puma here!
where is the fan switch on a puma
Old Aug 2, 2010 | 09:57 PM
escort1989uk's Avatar
escort1989uk
Default where is the fan switch on a puma
tried to see if i can bridge the connection to see if my fan works tried the one that plugs into the thermostat housing under the coil pack but that controls the temputure gauge. and as its dark i dont fancy rolling round searching unless some one is 90% sure they can point me in the right direction
thanks in advance for any help given
Old Aug 3, 2010 | 03:40 PM
I don't know the puma engine wise, but the fans may be ecu controlled, so there may not be a "normal" type rad switch.
Old Aug 3, 2010 | 07:02 PM
zippyobrien's Avatar
zippyobrien
its under the coil pack. sensor tells the ecu how hot, then ecu controls fan and gauge.
fun cuts in at 110degrees c on them,
when a sensor fails on a puma it usually brings the fan on perminently,
look at the hcv valve for overheating issues.
Old Aug 3, 2010 | 07:29 PM
As said above the ecu controls the fan.My mater has a mk4 fiesta,i found out the fans dont work on that and they are controled by the ecu.
Old Aug 3, 2010 | 09:41 PM
escort1989uk
well all sorted the someone had wired it back to front you are all correct after a hour with a multi meter i trace voltage to all connection but on the fan cowling is a risitor coil looking thing well the sensor plugs grey and the same shape as the fan motor connection and the colour only seen when i unplugged them only relised the coulors while i was testing the electric. so lesson learned.
Old Aug 4, 2010 | 01:58 PM
zippyobrien
i had the connectors the rong way round when i did my first puma conversion, right pain in the arse.
dunno what that coil looking thing does ?
Old Aug 4, 2010 | 06:03 PM
The coil looking thing is no doubt a resistor for dual speeds ie air con etc.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
youngben
Sep 27, 2015 09:37 PM
cossie330
Sep 27, 2015 04:13 PM
Marv888
Sep 26, 2015 03:44 PM
