Lightest I/cooler rad and turbo cooler setup, pro alloy, A and H, ???
Which is the lightest package available for a sapphire cosworth, pro alloy tend to perform best so what are the weights of each individual item please and as a package, fans, bracket, icooler/ rad and post turbo cooler.
Weights of the best coolers rads etc would be useful thankyou all
My AH doesn't line up with the turbo so needs cutting and welding and the exit modding for my the inlet, and it weighs a ton, I'm not impressed, it doesn't flow as well as a pro alloy end tank either- its not as smoothly rounded, any comparable weights of the pro alloy parts in grams?
I would be looking at the best not the lightest, if you have under 500hp dont bother with the turbo cooler as this only adds weight
As most are made with sim cores and end tanks a AH would be close to a Pro alloy.
Mark
Even when running antilag Mark? I only fitted the turbo cooler when I had the anti lag to help the water temps. I have now fitted and oil cooler and new thermostat which have helped so maybe try without the cooler for a while again? Temps were an issue at high engine speed RPM while at low rolling speed MPH
Proper ALS is slighty diff so you need to keep a eye on it,
What do you mean low rolling speed and high rpm.
Mark
While drifting in 1st and 2nd gear on the standard limiter with little forward movement, maybe 40MPH forwards? the oil temps went high, oil pressure lower, water temps off of the scale and fans on constant. That was without the MSD mild ALS on or an oil cooler though.
I now have a 13 row oil cooler and MSD fan switch and 82 degree thermostat, so maybe try without the water cooler this time
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
track.focus'd
Aug 12, 2015 05:53 PM
