Recommended fuel for Focus RS?
Hi folks,
A mate of mine has just bought herself a Focus RS. She's planning on running it on normal unleaded. Not Optimax or even SUL. Is that safe for RSs? My background is tuned Imprezas, and I wouldn't even think of running normal unleaded. Her car is standard and will probably go on a race track once in a blue moon. Is she OK with normal U/L ?
I don't know much about the focus rs, probably since there isn't a single one here in iceland
.. but most people I know who have turbocharged cars run them on 98/99 octane gas.
So that's what I'd do, just to be on the safe side.
.. but most people I know who have turbocharged cars run them on 98/99 octane gas.So that's what I'd do, just to be on the safe side.
Thanks ses. Yes, I would run a higher grade fuel regardless.
I'm hoping that an RS owner will pop up and let us know for sure. There's probably a note in the owners guide to indicate which fuel should be used.
There should be something in the owners manual but as far as I know the engine is setup for higher octane fuel ONLY!
Basically DO NOT use normal Unleaded unless its an emergency and you cant find any optimax or super unleaded! I think Ford recommends 97RON or above!
Rich
Rich
Thankfully she's had the car less than a week, so there's (hopefully) little damage done. She also ran her old ('97) Prodrive-tweaked Impreza on 95-RON
. I *do* hope she's learned now. Leave the cheap fuel for the cheap cars! Decent car? Give it decent fuel.
rs: hasn't she wondered why her cars keep going bang? They're not all RSs, are they? Buy her a bottle of octane booster for her birthday. Even if it's not her b/day in the near future it's a good opportunity to lay heavy hints that her car needs proper attention!
. I *do* hope she's learned now. Leave the cheap fuel for the cheap cars! Decent car? Give it decent fuel. rs: hasn't she wondered why her cars keep going bang? They're not all RSs, are they? Buy her a bottle of octane booster for her birthday. Even if it's not her b/day in the near future it's a good opportunity to lay heavy hints that her car needs proper attention!
Originally Posted by LeviA
Mine gets what it's given... sometimes 95 sometimes 97/98, I don't believe it does that much harm running 95 ron then running 98 ron every 3rd or 4th fill up.
The FRS has no knock sensor to advance or retard the ignition dependant on the RON of the fuel being used!
That is why inside the filler cap it states 97+ RON!
In other words the lowestst RON value fuel you can use is BP Utimate (97 RON) & Shell V-Power is now increased to 99 RON from the existing Optimax which was 98.6 RON.
I'd rather run out of fuel! V-power is the ONLY option for these IMHO
