Sapph suspension.
Old Aug 1, 2010 | 06:08 PM
bubba sparxx's Avatar
bubba sparxx
Default Sapph suspension.
Hi folks,put some koni lowering springs in my saph 4x4 but its still higher at the rear than the front,is there anything i an do i.e. change rear shocks to have the rear lower?if so what shocks do i go for?thanx in advance.
Old Aug 2, 2010 | 05:05 PM
I'd leave a while to settle down first height wise, say a good month or fuse to really settle height wise, a slight arse in the air attitude is ok, that's how mine is(on coilovers).
Old Aug 2, 2010 | 09:05 PM
English's Avatar
English
Read in a suspension set-up guide in Fast Ford a while back that the back should be an inch higher than the front
Who knows? Like Tabetha said, give it a chance to settle in as well, or fill up your fuel tank
Old Aug 3, 2010 | 12:08 AM
bubba sparxx
cheeRS chaps failing that a concrete slab in the boot
Old Aug 3, 2010 | 01:22 PM
I run mine between 3/4" and 1" higher at the rear, mainly due to being better on speed bumps etc with people in the car.
Karl 3dr
102
Oct 14, 2016 08:17 PM
DavidK
Sep 27, 2015 02:55 PM
Cos500
14
Sep 2, 2015 05:48 PM
pegaz
11
Aug 9, 2015 06:40 PM
CosRush
Jan 2, 2004 10:53 AM
