ST170 Accelerator Cable Problem
Old Jul 29, 2010 | 01:24 PM
GAZZAST170's Avatar
GAZZAST170
Default ST170 Accelerator Cable Problem
I've noticecd recently that when I put my foot down on the accelerator pedal it isn't very responsive alos the pedal seems 'floppy' is this just a case of adjusting the accelerator cable? The car drives ok just seems lacking in power when I put my foot down straight away, seems to take a second or two to acknowledge its being pressed!
Also were is the accelerator pedal located and is it easy enough to adjust?
Old Jul 29, 2010 | 03:40 PM
ricky_2006's Avatar
ricky_2006
sounds like a st170 lol
has that always happend?
zetec engines stutter at like 2-3k then pick up after
Old Jul 29, 2010 | 09:40 PM
Sp3no's Avatar
Sp3no
The cable runs across the top of the cam cover from left to right, the adjuster is on the left side of the cable. They are known to need adjustment to fully open the butterfly. I ported my throttlebody and throttle response is crisp and instant, but there is a flutter at 2000rmp as there are with most and i have a remap
Old Jul 30, 2010 | 06:49 AM
kristinthomas21's Avatar
kristinthomas21
The cable passes through the upper part of the cam cover from left to right is the knob on the left side of the cable. They are known to need to adjust the throttle fully open.
Old Jul 30, 2010 | 01:04 PM
GAZZAST170's Avatar
GAZZAST170
No only recently started. Thanks for info guys
Old Aug 2, 2010 | 08:47 AM
GAZZAST170's Avatar
GAZZAST170
Have adjusted the cable and pedal seemed a lot better for a day or so. But has started to feel a bit 'loose' again. Could this be an issue with the accelerator cable or pedal itself?
Old Aug 2, 2010 | 04:06 PM
TomEbbs's Avatar
TomEbbs
Correct me if im wrong but im pretty sure there was a recall on some cars regarding throttle cable...
Its in relation to is path through the engine bay...
Old Aug 3, 2010 | 12:29 PM
Sp3no's Avatar
Sp3no
They recalled the accelerator cables as the shorter ones could cause a vibration to be felt through the accelerator pedal, that was all. I still have the shorter cable and cant say i have ever felt any vibration. The longer cables look stupid any way as it means the cable is draped right over your cam cover
Old Oct 9, 2010 | 03:10 PM
scottyfocus's Avatar
scottyfocus
just bump this thread, but this sounds alot like whats happening with mine, although i have no basis to compare as ive just bought it.
ill put the pedal right down, seems to take a second to respond. Also i get a very light tapping, very rapid through the pedal and i would describe the pedal as being light, although like i said i dont know what it was like before.
Any suggestions?
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
landaqmabba
Sep 15, 2015 07:16 PM
Bransby
Sep 14, 2015 08:54 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
Marino
Sep 12, 2015 11:10 AM
