Cosworth parts clearout
Old Jul 28, 2010 | 07:41 PM
Steve Escos's Avatar
Steve Escos
Default Cosworth parts clearout
Lots of spares as I want my shed back. All parts are used unless mentioned and all are plus postage. All are in good condition and pics are available on request.
Parts are located in Scunthorpe or I can take some parts to Ford fair however they will need to be paid for before either in full for low value items or at least a deposit for higher value. I Will do deals if multiple parts are purchased.
Any questions drop me a line. Payment is cash, cheque or paypal (either as a gift or you pay the fees)
Steve 07725238098
2wd oil pump 30
2wd oil pump 30
2wd heatshield 40
2wd front calipers 50
4x4 front discs 20
set of cossy bronze valve guides NEW 60
3dr spoiler brackets 50
3dr auto specialists grille brackets 15
2wd lower rad pipe stainless SOLD
2wd thermo to matrix pipes 5
3dr fuel tank level sender 45
2wd clutch arm and pin 40
2wd discs rear drilled and grooved 30
2wd discs front drilled and grooved 40
315mmx32mm discs drilled 70
turbo water feed (I have 3 of these 2 X long, 1 short) 5 each
2wd thermostat housing polished 10
flywheel 25
flywheel 25
3dr tank strap NEW but has storage marks non Genuine 5
3dr rear passenger arch - moonstone SOLD
3dr rear driver arch tatty 10
2wd tca pair for sapphire NEW 50
2wd exh manifold no trouser section 20
2wd 3 v belt crank pulley 45
crank sprocket 5
crank sprocket 5
2wd turbo damper 15
2wd turbo damper 15
bottom crank cover 8
aux jack shaft 10
aux jack shaft 10
distributor 10
distributor 10
power steering pump 25
2wd clutch cable gaitor 10
throttle body bare 5
escos passenger side skirt in primer 80
4x4 crank pulley puller 25
3dr drivers side pillar pod 30
+0.5mm mahle piston ring set NEW 80
2wd front wheel bearing NEW 20
NGK9 plug set NEW 40
8 escos side skirt clips SOLD
cometic setC4248 NEW 70
exhaust gaskets NEW 10
55 housing NEW 250 Delivered
Stem seal set NEW 5
Sierra stickerx2 NEW 15
Escos prop donut 40
Old Jul 28, 2010 | 08:58 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
pic of heatshield please mate is it good condition and 315mmx32mm disks
Old Jul 28, 2010 | 09:42 PM
RSCossieGaz's Avatar
RSCossieGaz
whats condition of 2wd drilled/grooved discs pls?
Old Jul 29, 2010 | 06:46 AM
davecosworth's Avatar
davecosworth
IM BACK
will take this pm me payment details and postage cost to croydon 2wd lower rad pipe stainless £10
Old Jul 29, 2010 | 08:52 AM
Steve Escos
All PM's replied too. Will upload pics tonight.
Regards Steve
Old Jul 29, 2010 | 11:51 AM
davecosworth
IM BACK
payment sent for water pipe many thanks
Old Jul 29, 2010 | 04:53 PM
Steve Escos
Pics uploaded. Discs are all good apart from surface rust. No lips or cracks to any of the discs.
Old Jul 30, 2010 | 08:44 AM
VEEDUBBED's Avatar
VEEDUBBED
Hi mate,
Have you got any alloy bells to go with the 315mm discs??,what make are they?
Thanks.
Old Jul 30, 2010 | 09:12 AM
Joe Grp4 Escort's Avatar
Joe Grp4 Escort
pm'd
Old Jul 30, 2010 | 09:35 AM
davecosworth
IM BACK
i have a spare set of alloy bells for these discs if some one needs them when purchased
Old Jul 30, 2010 | 10:10 AM
ossie cossie's Avatar
ossie cossie
Im interested in the 315mm disks if i can get the bells from dave cosworth. I am PMing him now.
Old Jul 30, 2010 | 01:16 PM
Steve Escos
All pm's replied to.
Sorry no bells for the discs.
Old Jul 30, 2010 | 02:10 PM
taittsierra's Avatar
taittsierra
Hey are front Calipers 4 pot's mate..?
Old Jul 31, 2010 | 06:49 AM
Steve Escos
Yes front calipers are 4 pots
Old Aug 3, 2010 | 05:43 PM
Steve Escos
UP!
3dr cossie
11
Dec 21, 2015 03:38 PM
TrevCos
Alloy wheels and ICE for sale
Sep 13, 2015 02:12 PM
155lee
14
Aug 22, 2015 12:15 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
