uprated mk 4 ecsort front and rear brakes
Right not sure what calipers these are off, their a similar size to a set of escos ones i had but arnt!!! been told they were poss st220 ones but the numbers on them are 817 and 818 if that helps?!
they come with the brackets and also spacer washers to fit the mk 4, and also the pads still have a fair bit of life and the discs only have surface rust on so should be fine to use if you want them too!! I have also checked the bleed nipples and pistons and they are free moving.
Looking for £100ono + postage for the lot (would estimate 20odd due to weight but would have to get that confirmed)
Also have a rear disc conversion for the mk 4, this came off the same car and consists of rear calipers, handbrake cable, mounting brackets and bolts to fit it all!! the discs and pads thou tbh are pretty shagged so would be best to buy new ones!! Have also checked pistons and bleed nipples on these too and are fine.
£100ono for these!
prices on both of these sets are ono so feel free to message me
£100ono for these!
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
