...will these fit my 3dr??....
Evening all
been offered a set of alloys for my 3dr
8.5j x18
et 18
tyres are 225/40/18
if rims fit but tyres cause problems width wise i can always get 215/35 etc
thing is i cant offer em up as cars in bits atm
can someone advise as they are in real good nick and been after a set like this for ages,though would have preferred 17s
ta folks
D.
8.5j x18
et 18
tyres are 225/40/18
ta folks
D.
Cheers pete,dya know what the standard et is on a 3dr
Will I have to get spacers,(am still trying to get my head round wheel et's)
Btw am running coilovers too or at least I was
That ofset is escos size mate so its a deffo no no...
You need around 33-38 et for on 17s really 18s at a push but as said car will drive better on the 17s...
Id go 8x17 et 33 so as to fit front and rear although you could get away with et 25 on the rears although you could just use an 8mm spacer to achieve the same look..
cheers danny
cheers danny
cheers danny
cheers danny
Rear: 245/35/17
Front: 215/40/17
Rich
sonic boom that looks nice fella
right have seen a set of rims
16in,
et 20,
7.5j
with 195/45/16 rubber (could i go wider?)
will these still be too wide ??
ps how does et work on a car ie how do you work it out,every time i see it i understand then when it comes to a time when i need to use the info its gone somewhere deep in the depth of my head
16in,
et 20,
7.5j
cheers mate
done gone and done a deal on em,had to really as they are pretty rare with a 108 pcd so if they dont fit my 3dr will just flog em on but gotta have a punt aincha
with 16in rims disks should also be cheaper as wont need to be as big
,done gone and done a deal on em,had to really as they are pretty rare with a 108 pcd so if they dont fit my 3dr will just flog em on but gotta have a punt aincha
just fitted 8.5 x 17 et33 but not run the car yet as the rads burst(3dr).the clearances look fine although very very close to the caliper.what surgery did you have to do to the fronts?
Billy_RS
16
Oct 11, 2025 09:41 PM
