Braided lines
have a look on ebay for user thracing09..he sells venhill power hose..you buy the lengths you need and he will put a fitting on the end..you then buy the banjo fittings you want and simply screw them onto the hose then fit into master cylinder/ calipers etc..may cost a bit but def takes away the arse on and risk of putting your own ends onto hose
Easy enough to do yourself if just buying hose and ends seperatly.Although wouldnt advise if not confident enough as last thing you want is a hose leaking.
Done a few rally cars with no problems.
