diff change, how?
i have a 1.6 cvh 2wd sapphire and have a welded diff that i want to fit. now my question is, i've been told that to change the diff i need to remove the rear hubs and springs to enable the driveshafts to be removed in order to change it. what i'd like to know is if there is an easier way of doing this without stripping the rear end?
i think im right but your center cvj puch into the diff so you will have to do as you have said on a cosworth diff you just undo the bolts drop the cvj and off with the diff
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
