Where to route ABS loom on 3dr?
Old Jul 20, 2010 | 06:52 PM
g10ens's Avatar
g10ens
Default Where to route ABS loom on 3dr?
Anyone know the correct route the ABS loom should take after it exits the bulkhead into the engine bay on the passenger side of the car? It has to get the ABS pump on the drivers side. Does it run along the passenger chassis leg then along the front crossmember where the lighting loom is and then up the drivers chassis leg or does it just go straight across the bulkhead somehow?
Old Jul 20, 2010 | 10:00 PM
Yogi.'s Avatar
Yogi.
in lhd 3dr´s it goes along the front crossmember.
chears
Yogi
Old Jul 22, 2010 | 06:37 PM
g10ens's Avatar
g10ens
I'll asume a rhd one will be the same then, thanks.
Old Jul 29, 2010 | 11:08 PM
g10ens's Avatar
g10ens
Doesnt seem to be long enough to go along the front crossmember, i thought it wouldve run along there with the lighting loom but just seems too short to do that, and its definitely too long to run straight across the bulkhead so ive ruled that one out, had a look on a mates 4x4 saff earlier and it doesnt run along the front crossmember on his from what we could see (which wasnt much because of all the hoses etc in the way) it seems to run along the bulkhead on the 4x4 saff so im assuming its different to the 3dr. So im a bit stuck now, anyone know?
Old Jul 30, 2010 | 06:23 AM
B13 JUS's Avatar
B13 JUS
it comes out from under batterey tray then straight across the bulk head above the rocker cover to the servo/pump. the passage side abs sensor runs along the chassis rail.
Old Jul 30, 2010 | 09:00 AM
g10ens's Avatar
g10ens
Thanks for the info, il get out there and get it clipped in place later on.
tankybaby66
Feb 6, 2016 02:24 PM
muz
Sep 30, 2015 08:29 AM
