Best way to polish stainless steel exhaust ?
Old Jul 20, 2010 | 10:25 AM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Default Best way to polish stainless steel exhaust ?
As per title - just wondered what products I need and how hardcore i need to get with it to get a decent shine into it if that is actually even possible.
The exhaust in not new - has been on the car for a while and it would be great to get something close to a mirror shine into it but i guess that is asking a bit much.
Old Jul 28, 2010 | 12:06 AM
RSEDD's Avatar
RSEDD
Tailpipe and rear box or whole exhaust???
If tailpipe and Rear box then AutoSol fed on with a rag in circular motion till your arm hurts is very good and shines like a mirror.
For the whole exhaust i would hazard a guess at using a fine wet and dry with a machine, followed by Autosol...Hard graft for the whole thing, but a few hours work if just doing the rear less heated part!!!
Old Jul 28, 2010 | 12:12 PM
Cossy Mike's Avatar
Cossy Mike
If it's really bad and the front pipe has gone Blue get an angle grinder and put a wire cup brush on it, then soak the exhaust in WD40 and skim over it with the angle grinder.
DO NOT use angle grinder on the polished boxes or the tailpipe, ONLY the main pipework.
Then wet n' dry sand paper ultra fine THEN use Solvol autosol and it will be like a mirror.
Don't waste autosol on your exhaust to begin with you'll use tubes of the stuff and it's expensive
Old Jul 31, 2010 | 12:04 AM
Retro Al's Avatar
Retro Al
RWD IS KING
Autosol and fine wirewool
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
