Which Cams for Sierra RS Cosworth 2WD?
Hello
I hope you understand me
my english is bad
so i need new cams for my sierra rs cosworth 2WD.
i will get a GT35 Turbo.
http://cgi.ebay.co.uk/RS-Cosworth-2w...item255528b831
is this a good kit? or which cam should i buy?
Thx
Alex
Thx
Alex
The best thing you can do is ask one of the tuners on here (only a matter of time before one of them look) to see what the rest of the spec of your engine is, and how you want it to drive, a GT35 is a pretty big turbo, so make sure you get one that works well with it. I know BD14 is quite popular as a fast road cam, but I think it depends in the whole engine spec rather than just the turbo size (things like compression ratio), and your english is perfectly fine.
(and if theres anything I've said wrong someone please correct me)
Thanks for the answer.
These are my specs until now.
I got a new Csoworth Block
under piston spray jet
6 lon Studs and 4 arp head studs
Biw wing sump
Berham oil pump (grp. a)
race bearings
balanced crankshaft
balance h-shaft rods
special rod bolts
Low Compression 7.5:1 MAhle pistons with valve cutouts
windage try
4*4 water pump
cooper ring gasket
thx alex
Biw wing sump
race bearings
balanced crankshaft
special rod bolts
windage try
4*4 water pump
cooper ring gasket
thx alex
Biw wing sump
race bearings
balanced crankshaft
special rod bolts
windage try
4*4 water pump
cooper ring gasket
thx alex
Biw wing sump
race bearings
balanced crankshaft
special rod bolts
windage try
4*4 water pump
cooper ring gasket
thx alex
cheers danny
Aug 14, 2015 07:29 AM
