Cosworth parts
4x4 Gearbox - £40(3rd gear gone) sold
ford motorsport leads done about 600 mile £45
4x4 ABS ECU £15
4x4 front braided brake lines £25 as new sold
used inlet valves £10 each got 8 done about 20k
used exhaust valves £15 each got 7 done about 20k
set of standard blue injectors £40
Front Dif - £60 done 91k sold
Rear Dif - £90 done 91k sold
4x4 Sump with shaft £40
2wd exhaust manifold trouser piece £20
escort cosworth undertray (offers)
4x4 abs sensors £45 each
4x4 adjustable steering column with barrel & key £70
4x4 engine mount arms £20 for pair
saff 4x4 Bonnet with vents in silver - £80
standard airbox sold
2 Clear Indicators - £15 for pair sold
4x4 Steering Coupling - £35
4x4 Both Propshafts - £65
saff 4x4 Dash Clocks - £35
Vibrotec 4x4 Engine Mounts - £60 sold
Mirrors - £20(pair)
.48 backhousing to fit T34 £90 sold
Engine Beam - £30 sold
Power Steering Pump - £20 sold
Front Drive Shafts - £40 each
Rear Drive Shafts - £30 each sold
saff boot with spoiler in silver £60
set of standard rods £100 ono
set of isky valve springs offers done about 20k sold
standard ground crank £400
2.5 bar map sensor £25
4x4 flywheel £35
bd15 inlet cam off 4x4 done about 20k £70
newman bd14 exhaust cam to fit 4x4 only done about 600 mile £85 sold
newman bd16+ inlet cam to fit 4x4 only done about 600 mile £85 sold
4x4 cam belt cover £20
4x4 thermostat housing £35
4x4 exhaust manifold no cracks £35
4x4 heater matrix £15
Please Contact Andy on 0785 536 9009 can post
4x4 ABS ECU £15
Mirrors - £20(pair)
4x4 flywheel £35
sorry m8 my computer has been down 4 last 2 days just got it sorted. I just need 2 check if i still got both driveshafts might of sold one will check in mornin but definatley got other items send me ur mobile number & i will call u in mornin 2 arrange collection or u can call me on 07855369009 cheers
bye bye
