Building up a 200 block
Old Jul 18, 2010 | 05:43 PM
BRAMMER's Avatar
BRAMMER
Default Building up a 200 block
I am removing the bottom end from my 3dr and selling as a short motor so will not be scavenging any parts to build up my new 200 block. i have the pistons already that came with the block.
What i need to know is what:
Oil pump - 2wd or 4x4
Pickup - 2wd or 4x4
Water pump - 2wd or 4x4
dipstick tube - 2wd or 4x4
Crank pulley - 2wd or 4x4
Crank - 2wd or 4x4
Conrods - 2wd or 4x4
Any info appreciated and if i've missed anything
Also is a .25 crank ok to fit in an engine that could possibly run up to 500bhp
Chris.
Old Jul 18, 2010 | 06:40 PM
Danny @ Enhanced Performance's Avatar
Pickup - 2wd or 4x4
Crank - 2wd or 4x4
Chris.
Hi there,
Oil pump is worth going 4x4 but not essential
Water pump 4x4
dipstick and tube 2wd
Crank and pulley doesnt matter
Conrods dont matter
And a .25 crank will be fine..
cheers danny
Old Jul 19, 2010 | 01:12 PM
BRAMMER's Avatar
BRAMMER
cheers danny
Danny if i go for a 4x4 pump will have to get the 4x4 pickup??
Also will this lot go on without modifying the 2wd sump?
If you use the 4x4 water pump do you have to use the 4x4 therm housing?
Cheers Chris.
Old Jul 19, 2010 | 07:06 PM
Cheers Chris.
there is a way around the pick up but cant remember i will ask luke..
The 4x4 water pump doesnt mean you will need the 4x4 stat but its a better stat anyway so you may aswell if youve got one...
cheers danny
Old Jul 22, 2010 | 08:33 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
You got a crank?
I have a fresh round .25 ready to go.
Got rods, pick up and pump stil in old bottom end too.
Old Jul 23, 2010 | 04:31 PM
bad boy rs's Avatar
bad boy rs
how much for the short motor mate ?
Old Jul 24, 2010 | 02:34 PM
BRAMMER's Avatar
BRAMMER
I won't be removing until the winter mate, i don't actually know the spec other than it was rebuilt 2900 miles ago using standard Ford bearings, Grp A head gasket etc and has produced good power and continues to be noise free.
I'm really only wanting a std late 4x4 crank due to the power but with the car coming off the road for a few years i'm no rush.
Old Jul 24, 2010 | 03:31 PM
Gav Diamond's Avatar
Gav Diamond
Brammer,
Im not 100% but i think because your block has 10 long studs you will need to modify whatever water pump you intend to fit.
Old Jul 24, 2010 | 04:16 PM
RS SHAUN's Avatar
RS SHAUN
I might be intrested in your old short motor chris
cheers shaun
Old Jul 24, 2010 | 04:20 PM
BRAMMER's Avatar
BRAMMER
Originally Posted by Gav Diamond
Brammer,
Gaz i think something has been done your right as their is a dowel type thing that goes somewhere round there - i can get hold of the water pump if need be. I'll check this afternoon cheers for that info mate
Shaun again i will remove and check everything is fine and then i might be able to get more info from it, pistons etc but it won't be until winter.
Old Jul 24, 2010 | 04:39 PM
bad boy rs's Avatar
bad boy rs
Ok mate well give me a shout when it's up for sale as mines smoking heavily now and will be coming out in the winter
Old Jul 24, 2010 | 05:17 PM
james kiely's Avatar
james kiely
are you doing a full restoration chris ?
Old Jul 24, 2010 | 08:41 PM
BRAMMER's Avatar
BRAMMER
No Just engine and underside James, well for now
Old Jul 24, 2010 | 11:29 PM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
Brammer,
Needs machined back at 45 degrees for clearence from the long studs , what i was told and made me back away from 10 long studs
Here goes a stud and nut kit
Old Jul 25, 2010 | 12:44 AM
BRAMMER's Avatar
BRAMMER
I have the pump coming my way that was in this block so i will see what was done when i get it.
Nov 1, 2015 06:53 PM
chowfornow
Alloy wheels and ICE for sale
15
Oct 17, 2015 07:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
