hi mate ive just done this conversion on mine i had 4mm machined off the inside edge where it meets the hub and tapped the hubs out. i used 283mm disks cant remember if they were 2wd or 4wd. check out the rsbible website all info you need there mate.
looking at your build thread it dont look to bad to do
If your running 16's or bigger then fit Focus ST170 300mm discs, with mondeo calipers and pads (same caliper as ST but cheaper!), they work a treat and are a direct fit using a 12mm spacer available on ebay
