Screamer Silencer for External Wastegate
Old Jul 15, 2010 | 09:25 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Screamer Silencer for External Wastegate
Here is the Screamer Silencer I built just before I pulled my RST apart. It is 38mm and was made to run alongside a 3" exhaust. The outside diameter of the silencer is about 3".
The flange is a normal Tial flange, you obviously run a Screamer pipe down and under the car, then make the join to this Silencer, I planned it so that you could remove the Silencer and run the Screamer unsilenced if you wanted. It's like new, as it did one run to Brunters. It takes pretty much all the noise of the External Wastegate, it worked really well.
I'm after £80 for it.
Old Dec 2, 2010 | 04:38 PM
Christian and Beccy
#1 in Spelling Club
This finishes on Ebay tonight if someone wants a Billy-Bargain!!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...STRK:MESELX:IT
Item number : 160511057586
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
pabloXR
Sep 21, 2015 12:42 PM
coscor86
Sep 20, 2015 01:21 PM
RSBryden
Sep 6, 2015 08:39 PM
