handbreak light
hello people
my hand break light dont seem to work on my s2
ive took the abs out but linked the wire up so it makes the circuit
and ive checked the bulb in the clocks
so could it be a dodgy wire from the handbreak to the clocks? or could it be the sender?
many thanks
many thanks
happened to me aswell..turned out to be the rubber plug on the fluid resevoir. the connections inside had corroded
edit to say i used a plug and cap off a later escort..they are plastic clip on type betterthan the rubber type
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
