Clarke Industrial Air Compressor -
like new only used a couple of times £300
14cfm displacment - cast iron, twin cylinder air compressor pump
150 litre air receiver (CE certified)
3hp motor, 230v, 1ph continuously rated with overload protection
10bar (150psi) maximum working pressure controlled by a fully automatic pressure switch.
Specification also includes safety valve, pressure gauge, air outlet valve & drain tap.
Application - these air compressors are perfect for professional automotive/industrial use
Dimensions (LWH) 1390 x 420 x 920mm, Weight 97.5kg
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
