escort bits and bobs
sold
adjustable tca £75
2 x handheld 2kg's powder extinguishers £30 the pair
wilwood lever still proportioning valve (new) £40
long hydraulic vertical handbrake assemberly ver good condition with a .625 cylinder £75
sold
sold
escort mk1/2 cossie turbo alloy radtec radiator(fitted in my mk1 at present)it has a 65mm core,measure's 21 inches across the top and 18 inches down the sides,has thread for fan/stat control etc and is mint.i spoke with radtec today and this item is bigger than there normal rad/cooler items they sell as lee wanted a bigger rad when building the escort.ran perfect temps with a t34 and over 400 hp and when sat in traffic never got hotter than 98 degrees. £250 this mint and polished.
complete stand alone water system to run a water cooled turbo,this is only just over a bloody week old(going a different route now power wise so not needed) again all polished radtec tank and radiator (fitted under my boot floor) measures 12inches long/3 1/2 inches high with a 40mm core again polished 13mm outlets and feeds all new rubber pipe work to run from boot to engine bay.also has an audi r8 bosch electric water pump inline (brand new) switched and relayed.i have the recipet(sp) for all of this im looking £400 for the lot.this set-up took near 15 degrees of temp out on the cooling system when used on track.
strab 19 row oil cooler done basicly 2 3/4 hours on engine dyno and minimal road miles.with new stat controller -12 lines and bling fitting(fittings and pipe was near £300 on its own.mounts nice in the front of escort mk1/2.the only thing needed for this is the sandwich plate on the oil filter take off from the block £350
fibreglass mk2 rs2000 bonnet very good con(full not just a skin) £70
for some reason i cant add pictures but i will try sort some out over the weekend if i can sort photo bucket out.cheers for looking
either pm or call 07877160771
adjustable tca £75
sold
sold
