2wd vs 4wd manifold?
Old Jul 8, 2010 | 05:17 PM
WongRS's Avatar
WongRS
Default 2wd vs 4wd manifold?
i know its been done before, but whats the advantages/disadvantages from moving to a 2wd from my 4x4, i take it a 2wd downpipe is needed too?
And the main one, is it easier to fit the bloody turbo with a 2wd one?!
Old Jul 8, 2010 | 05:23 PM
JamesH's Avatar
JamesH
2wd better for higher power (not as restrictive)
4wd better for NVH
Old Jul 8, 2010 | 05:29 PM
Joshy's Avatar
Joshy
Dreamer
NVH?
Old Jul 8, 2010 | 05:39 PM
RSGARETHW's Avatar
RSGARETHW
always working
dan... 2wd less restrictive but a little bit more laggy ans only really needed when going above 400 so im led to believe
4wd more responsive and good for upto 400... i had a 2wd manifold on my can and have taken it off and gone back to 4wd ... the choice as they say is yours ...
Old Jul 8, 2010 | 05:42 PM
WongRS's Avatar
WongRS
keep 4x4 then i think, thanks for that mate , just need to sell my internal organs, buy a turbo, send chip off the msd and get it all back together, in 4 weeks..............
Old Jul 8, 2010 | 05:51 PM
RSGARETHW's Avatar
RSGARETHW
always working
piece of piss.. mines taken 5 years.. still i dont do deadlines.. suprised i got married on time
Old Jul 8, 2010 | 06:06 PM
martysmartie's Avatar
martysmartie
NVH= Noise, Vibration and harshness, quiter etc so a better ride.
As said for the differences between the two.
Martin
Old Jul 8, 2010 | 06:12 PM
JamesH's Avatar
JamesH
As per Martin
Old Jul 8, 2010 | 06:59 PM
RSGARETHW's Avatar
RSGARETHW
always working
plus with 2wd manifold u would need a bailey turbo damper
Old Jul 8, 2010 | 09:10 PM
charlie luciano's Avatar
charlie luciano
Also if you have a turbo the size of frankensteins head you need a 2wd manifold other wise turbo won't fit, it will foul the side of the head
2wd manifold comes in 2 pieces, the main body of the manifold and the 'swan neck' the bolts that hold the two pieces together can be a pain in the arse to source too has a better top end flow rate as said its adviseable to use a turbo damper, takes the pressure of the manifold studs again especially if you have a big turbo
4x4 manifold is a single piece unit
Luciano
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
caprixpack
Sep 25, 2015 07:53 PM
