Cam Cover refurb >pics<
refurbing a c20let cam cover for my brother,
planed to just scrub with degreaser,
sand,
then etch prime the cover and spray with normal spectral blue aerosol
(a genuine vauxhall colour)
was in halfords today (im a pikey cunt
) buying stuff and the guy behind the counter started banging on about needing high heat paint,
shurly it wont get that hot.. and normal paint should cope with 150-200 degrees max shouldent it?
and if it does, then how do i get the paint to stick to the ally without an etch coat.
should i use a mist-coat with the high heat?
i still think normal paint should cope as you can powdercoat a cam cover and that aint a high heat proof finish???
sand,
) buying stuff and the guy behind the counter started banging on about needing high heat paint,shurly it wont get that hot.. and normal paint should cope with 150-200 degrees max shouldent it?
well it arrived today,bloody heavy for a rocker cover these c20let parts HAHA
well its in the bath at the moment soaking after a spray of WD40.
give it an hour then i'll rinse and i got some millers degreaser and brissle brush work to do.
excuse the "dirty" mags in the background
im a ford man at heart.
pizza box worktop available from burtons
