brake fluid
Old Jul 5, 2010 | 12:18 PM
turbobill's Avatar
turbobill
Default brake fluid
what brake fluid do i now use as ive taken my abs of my s2, is it the same or not ??
sorry for the dumb question
cheers
Old Jul 6, 2010 | 08:38 AM
turbobill's Avatar
turbobill
anyone??
Old Jul 6, 2010 | 10:33 PM
tomS2-Rst's Avatar
tomS2-Rst
Same mate Dot4. you could use 5.1 if you was ganna track it and get the brakes really hot. just use normal Dot4 and make sure you bleed it right throught.
Remember that brake fluid is hydroscopic (absorbes moisture) and should be changed every two years to keep boiling point up and avoid brake fade.
Old Jul 6, 2010 | 10:35 PM
turbobill's Avatar
turbobill
oh rite ok mate thanks for your advice
muzzman1
Sep 30, 2015 08:59 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
