scrap saph or escort cosworth engine for mock up wanted
virgin only up the A hole
can be a mullered engine ready for scrap yard no ancillaries required just block and head not even a sump thanks
that will do is it free to a good cause and could you pm me your postcode so i can work out postage i presume stripped will mean bare block as this will keep weight down would it be less than 25kg stripped thanks sy
if u get stuck ive got 2 scrap blocks, one has been sat in the garden for years and is all rusted so deff no good to me and welcome to it, the other has cracks around 3 bolt holes so not much good either but was gonna look at whether it was salvageable!!
the rusted one sounds ideal m8 can you pm me postcode so i can work out which courier to use thanks sy
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
