Standard con rods and largish power???
Old Jul 3, 2010 | 05:34 PM
Rob_DOHC's Avatar
Rob_DOHC
Default Standard con rods and largish power???
Just wondered if any one had good results (like the rods didn't break) with standard rods and over 200brake....
Rob,
Old Jul 3, 2010 | 05:48 PM
tomS2-Rst's Avatar
tomS2-Rst
Nope. lol. mine thew a rod.
Old Jul 3, 2010 | 06:17 PM
project rs's Avatar
project rs
the rods are ok till around 220ish but if you plan on reving it quite high then i'd uprate them but keep standard pistons
Old Jul 3, 2010 | 09:12 PM
Rob_DOHC's Avatar
Rob_DOHC
hahah, cheers
Just trying to work out if i can be bothered to spend the dosh and set a rev limit of 7k, or be a jew and set the rev limit to 6250 and lump it lol RPM i think puts much higher loads on rods than cylinder pressure....
Have you ever removed gudgeon pins from standard cvh pistons mate? i was told by my local machine shop that every time they have pressed a pin out from an rst piston they have cracked the skirt because they can't support it properly.... all the motors i have done in the past have floating pins and clips. Some one suggested heating the piston and lightly tapping the pin out?
Rob,
Old Jul 4, 2010 | 09:43 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Originally Posted by Rob_DOHC
hahah, cheers
Rob,
your local machineshop shouldn't be used in my opinion, you can't simply press them out, they need heating up significantly and then they slide out easily.
muppets if they think force is the answer.
also, get H section rods, i'm starting collecting parts for my new ZT and rods are on the top of the list along with pistons and heqvy duty bearings.
doing it cheap isn't always the answer as i've found out on my zvh.
Old Jul 4, 2010 | 09:55 AM
jonny s2's Avatar
jonny s2
anything over 250hp and id change the rods
Old Jul 4, 2010 | 10:28 AM
crazycage's Avatar
crazycage
my cvh ran a solid 260hp for years on standard rods before i built my zetec. and back then if rods and pistons were the price they are now my zetec would never of been.
p-s it was going to cost around Ł1200 for rods and pistons i payed Ł500 for the zetec ones!!
Old Jul 4, 2010 | 10:33 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Hava a read mate.... https://passionford.com/forum/ford-e...-con-rods.html
Old Jul 4, 2010 | 01:09 PM
Antti O's Avatar
Antti O
Hi
My setup was proved 267.3bhp / 339nm torque. Standard bottom end.
This is second summer now and no problems.
Old Jul 4, 2010 | 01:13 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Mate ran 274hp through shot-peened standard rods, never had an issue in around 8k miles of abuse...
Wouldn't go over 250 personally though, as said.
gcfcos
88
Sep 15, 2015 03:48 PM
Marino
Sep 12, 2015 11:10 AM
CrOwSoN15
Sep 10, 2015 07:33 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
