Escort RS turbo.... help needed!!
Old Jul 3, 2010 | 11:04 AM
DanFR147's Avatar
DanFR147
Default Escort RS turbo.... help needed!!
I purchased a ERST 3 months ago with a view to restoring her back to her original standard condition over time. I noticed at high revs 4500 - 5000 my inter cooler was filling with oil. I had it compression tested today by PJ Motorsport in Wolverhampton, they concluded that piston 1 to 3 were fine but piston number 4 wasn't!
They said that I will have to have the bottom end bored out and bigger pistons fitted. This would correct things. However, while the engine is stripped I should replace the oil pump, water pump, bearings, gaskets and cam belt.
Can anyone advise/recommend somebody to do the work? How much are we talking to do the work? PM me or contact me on 07796 008817.
Old Jul 3, 2010 | 11:40 AM
Karlos G's Avatar
Karlos G
Balls Deep!
If your going to pay someone to do it, then I would imagine with parts somewhere between Ł1000 and Ł1500 mate.
Old Jul 3, 2010 | 12:35 PM
DazC's Avatar
DazC
You would be wise to have everything checked and replaces as PJ have suggested.
As you're in the west midlands, I would give Reyland a call.
Address:
Reyland Motorsport
Rear Of 1257 Pershore Road
Stirchley
Birmingham
B30 2YT.
Workshop Phone: +44(0)121 458 6010
Fax: +44(0)121 458 5030
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 16, 2015 06:38 PM
muz
Aug 16, 2015 12:57 PM
druidgetafix
Aug 15, 2015 10:22 AM
col93saphcos
Aug 7, 2015 03:21 PM
