ST170 Timing belt help
Has anyone got the locking tools they no longer need? Mine is due a belt change in 2.5K miles.
Not looking foward to it with the adjustable inlet cam.
Cheers for any help
Cheers for any help
there cheap mate, can get them from locla motor factors or probably on ebay.
alternatively use a 5mm bar in the back of the cams and a bolt of suitable size for a crank pin (haynes manual shows a home made one). its not thad bad a job even having to take the engine mount off but i've only done it on my 2l black top and not a st170 so not sure how you deal with the inlet cam
