Escort RS turbo series 2
First thing i done when i brought the car was an oil change. I've purchased Valveline fully synfectic 5w 30. Is this the wrong grade of oil for the car? Only when you put your foot down at high revs the car is filling the hose from turbo to inter cooler with oil. Is the oil to thin?
ive always used 10/40 castrol semi.What your using is normally the grade used for freshly built cvh,for the bedding in period.but tht also normally mineral oil.
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
