setting up actuator/waste gate
Old Jun 29, 2010 | 11:31 PM
smartrs's Avatar
smartrs
Default setting up actuator/waste gate
after recently swapping my turbo for another fresh one i noticed the turbo was not making positive boost which was quickly dignosed as te waste ate being open all the time due to different mounting of the actuator , so ive adjusted the rod so that it is closed in normal position is this correct or is there any thing else i should of done or have i got it all wrong ?
the car does seem to come on boost late ?
Old Jun 29, 2010 | 11:45 PM
mercgrey's Avatar
mercgrey
set it so on the wastegate there is around half the dia of the hole (on the rod end on) to pull over the waste gate!
hope that makes sence! lol
Old Jun 29, 2010 | 11:52 PM
smartrs's Avatar
smartrs
think so so its sligtly shorter than it need be and then make it fit ?
Old Jun 30, 2010 | 12:16 AM
mercgrey's Avatar
mercgrey
yeah you want to have to pull the actuator arm on slightly so its under tention
Old Jun 30, 2010 | 12:28 AM
smartrs's Avatar
smartrs
cool should be a easy fix tomorrow then, may need to use my shorter rod that i have as this one is all the way in
Old Jun 30, 2010 | 12:34 AM
mercgrey's Avatar
mercgrey
cool, you will be boosting again soon buddy,
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
lime
Sep 25, 2015 06:56 PM
timsrs
22
Sep 24, 2015 08:14 PM
