Diesel Gear Box
Old Jun 28, 2010 | 09:37 PM
gabbo's Avatar
gabbo
Default Diesel Gear Box
What are the roomers about these and are any of them true??
As i dont know what gear box i have in my ERST but its not an LSD but i have the chance of a low milaged diesel gear box for free, is it worth putting in as mine is leaking.
Old Jun 28, 2010 | 09:40 PM
botters's Avatar
botters
competant bodger
they are no stronger than a standard box, the ratio's are no good for rs turbo's and of course they have no lsd as well i personally would not bother unless you are desperate
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
bit of a mith that the diesel gearboxs are stronger they have longer ratios so the strain is taken off a bit im lead to beleave. they use the same bairings as th s2 box any ways
Old Jun 29, 2010 | 08:41 AM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
No lsd and as above they are no stronger but are better (APPARENTLY) for top speed runs as the ratios are different (longer, taller) whatever words they use!! but if you are desperate it will be ok for a bit mate
Old Jun 29, 2010 | 09:12 AM
Chris69's Avatar
Chris69
it will do fine but you will miss the shorter gearing i reckon
Old Jun 29, 2010 | 10:28 AM
dave_s2_rst's Avatar
dave_s2_rst
as above, the ratio's being longer make a top speed run better but you'll miss the rst ratios, which I think are spot on
Old Jun 30, 2010 | 11:08 AM
essexRSTSouthend's Avatar
essexRSTSouthend
Think i got a diesel box.As get 60Mph out of 2nd gear.At 80Mph,my revs sit just under 3K in 5Th.
Old Jun 30, 2010 | 05:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sounds like it mate! lol
Old Jul 1, 2010 | 11:47 AM
gabbo's Avatar
gabbo
Well ill just put this diesel box in for now and see how it goes as its free and if i find i dont like it ill be putting a wanted add on here for a propper LSD box from an ERST.
Cheers guys
Old Jul 1, 2010 | 09:15 PM
essexRSTSouthend
if mine is,then i love the gearbox.
Old Jul 2, 2010 | 05:33 PM
white2lsr's Avatar
white2lsr
Mine had a derv box in when I got it and I hated it. Pulled it out and chucked it i the bin. Now I have an LSD box in and its much better.
DHMC
Ford Fiesta
Sep 30, 2015 07:15 PM
`spotty
Sep 25, 2015 11:41 PM
IainRS1700T
Sep 25, 2015 06:44 AM
fordfiestamk3
Sep 11, 2015 12:52 PM
Bighandsuk
Sep 2, 2015 05:23 PM
