Front driveshaft removal..
How to?
I am stripping it and need to know the easiest or best way to remove it.
If I disconnect track rod end remove ball joint, anti roll bar, and frontstrut all in one will it simply pull off??
discs and caliper is already off
thanks!!
thanks!!
undo hub nut,
jack up,
Wheel off,
Undo the bottom ball joint pin or nut, lever down with a big bar and swing the hub free
pull shaft out
job done, 10 mins tops
it doesnt require any sort of suspension or brake strip down
jack up,
Wheel off,
pull shaft out
Do they simply pull out to remove them then? I was comparing them to the rear ones with the t55 torx bolts....
thanks
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
